Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
341 Questions View all
iMac - PCIe slot - yes / no
Hi.
Is there any article / info / etc. in order to confirm which iMac has PCIe slot?
I’m asking because I want to know if an iMac (14,2) with a default HDD (1 TB) has a PCIe slot too.
Thanks
EDIT - 12/29/2023
en.wikipedia.org/wiki/IMac_(Intel-based)
  • is this info correct ?
Add a comment
1 Answer
Chosen Solution
All of the 2012 ~ 2019 27” iMacs have both a SATA HDD or SSD (if you replace the HDD) as well as a custom blade drive interface. Here is a good reference which is more detailed on the interface which is different through the years The Ultimate Guide to Apple’s Proprietary SSDs
So you can get a real Apple SSD or I recommend going with the OWC pin compatible drives, I don’t recommend M.2 SSDs as much as I love them the addition of a converter makes them unreliable! There are other signal lines the Apple has that are not accessed by the M.2 SSD. Here’s the drive kit iMac Intel 27" (Late 2013-Mid 2015) Blade SSD Upgrade Bundle and the guide iMac Intel 27" EMC 2639 Blade SSD Replacement consider the amount of work to get to it to replace it and your down time.
iMac Intel 27" (Late 2013-Mid 2015) Blade SSD Upgrade Bundle Image
Product
$159.99
Score 1
Add a comment
Add your answer
JZ99 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 35
