2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
No Signs Of Life when plugged in- Unknown Cause, How to troubleshoot
I recenly got a a1342 late 2009 to 2010 and tried to plug it in with the included 60W power cable in the shape of a line and T. Nothing happened so I used a known working 60W charger in the shape of a line. I left it on charge for a bit and nothing is happening not even a light on the charger or a beep and i'm unsure on what to do next. Please help me!
Add a comment
1 Answer
Most Helpful Answer
I would inspect he MagSafe connector contacts as well as make sure the socket area is clean of junk which can hold the surfaces apart.
The cord LED needs to light up, are you getting Amber or Green light at all while holding the cord firmly into the socket? I would see if replacing the MacBook Unibody (A1342) MagSafe DC-In Board as often the insulator warps stopping the connection.
If that fails that aims us to a deeper logic board issue.
MacBook Unibody (A1342) MagSafe DC-In Board Image
Product
$19.99
Score 1
2 Comments:
The cord led is not lighting up and I know the cable works as I just used it on another device and it showed a led. I tried plugging it in after cleaning the port with 70% isopropyl alcohol on a Q tip on the pins and gunk beneath it though the cable is still not lighting up. What do you think I should do next?
by
@legperson123 - replace the MagSafe port. Checkout the part I linked in my answer.
by
Add a comment
Add your answer
Aussie Selo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 33
