2
Score
David Iwanicki
2.7k
Asked
won't boot from floppy, get error 41 when boot from HD
Here's a question for the "greybeards" out there:
I have a PowerBook 5300c, which when I attempt to boot it normally, gets an error 41 bomb when booted normally or with extensions off. I was running perfectly before I put it in storage a few months ago.
If I attempt to boot from a DiskTools2 floppy, it just spits the disk out and attempts to boot from the HD.
If I attempt to boot from a System 7.5.3 CD, using a SCSI external drive, I get a flashing ? icon, then it fails out to the internal HD.
The boot sequence appears to be correct; the bomb occurs right after the splash screen disappears, as the desktop is being drawn.
Thanks!
2
Score
mr5989
151
Answered
Accepted Answer
Just curious is the SCSI terminated? If I remember right this was the old key combo for a SCSI start up: CMD-OPT-SHIFT-DELETE-#
the # being the number of the scsi drive.
good luck
0
Score
glenhandy
49
Answered
-1
Score
Chris Green
13.6k
Answered
Im pretty sure that portable macs couldn't boot from SCSI(But i could be wrong, it's been a long time) you might have a hardware related issue such as a bad hard drive, if you can, try checking the drive for clicking noises, and that the SCSI Cables from the drive are ok, im not sure if the cd might be scratched, unreadable, or you may have the 68k version of system 7 designed to run on motorola 680*0 Cpus inolder macs, hope this helps.
-1
Score
mr5989
151
Answered
Internal was 0
external bus started with 1
I resolved the issue by formatting the internal hard drive and starting over. As an aside, this model will boot from a third-party external SCSI CD-ROM drive at ID 6. I'm currently about to replace the PRAM battery in this unit, documenting the process for some new guides.
David Iwanicki,
