Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20000 Questions View all
Adapter will not run notebook or charge battery
Upgraded hard drive but after putting it back together it would only run off battery power. The adapter will not run the machine or charge battery. Has any one else had this type of probllem?
Score -1
Add a comment
Chosen Solution
After you put the new hard drive in did you get it formatted? Can you see the new hard drive? Will it start from the CD? Put the old hard drive back in and see if the problem is gone. What drive did you put in? What color is the light on the AC adapter? This should not happen, so try removing the RAM and reseat just one at a time since that's the only compartment you were in, right? Did you open anything but the battery compartment?
Score 1
Add a comment
Most Helpful Answer
The first course of action is to ensure that everything is correctly plugged in to both sides of any cable that involve the left I/O board.
I would guess there is a bigger issue due to the machine running fine off battery power, but it's always good to remove any variables.
The next step would be to try a different adapter.
The next step unfortunately would be to replace the left I/O board.
Good luck! Keep us posted.
Score 1
Add a comment
Add your answer
Charles Johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,594
