2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Can I use power on pads without charger to try a A1342?
Hello, i bought a cheap macbook in flea market. But charger is too expensive for me at the moment. Can i try if it works by shorting power on pads without charger/ only battery? I checked battery's voltage with my multimeter and it gave me 11v so it must be charged.
Add a comment
1 Answer
There is a battery tester on the system with a set of small LEDs how many are lit and are they steady or blinking?
If the battery has enough power you can use the batteries power, but often these batteries are not long lasting as the use older chemistry which tended to degrade.
Add a comment
Add your answer
Polorchen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 29
