Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
115 Questions View all
Do I need to change the battery or something else.
I bought a MacBook Pro M1 2020 as a bargain.  The diagnostic error check came with PPP 007. When I switch on the laptop, the battery is 1% and it won’t charge even though I’m using the charger that came with the laptop. On the
Mac Battery Health-Service Recommended.
On CoconutBattery;
macOS Battery status- Check battery.
My question does it mean I need a battery replacement or ?
Update (04/17/23)
Update (04/17/23)
. This is the charger and it’s 61W
Update (05/02/23)
That’s the reply I receive from them
4 Comments:
Did you buy this new? Please post some photos of the charger.
by
I bought it used from an auction
by
Did you get any resolution on this? Did you try to replace the battery on your own? I am in the same situation, please let me know. your inputs might help me as well
by
@ashishkhedkar - I would just replace the battery, give this a read MacBook Pro 13" Two Thunderbolt Ports Late 2020 Battery Replacement it’s not very hard and it’s a lot cheaper than what the Apple or AASP will charge as they aren’t allowed to replace the battery alone (why I can’t answer).
Just take your time lifting the battery out and use just a little solvent at a time as you pull on the battery.
by
Add a comment
1 Answer
You could see if resetting the SMC fixes things otherwise the logic board needs repairs.
Reset the SMC of your Mac
The power regulator logic is messed up. This is not a battery or charger issue as we are getting power via the charger, the battery is just drained.
8 Comments:
Can the power regulator be fixed please? I’m in Finland currently.
by
@moussihabou - What happened with SMC reset?
If that failed the logic board will need repairs.
by
@danj it’s a mac with Apple silicon. MacBook Pro M1 2020. I checked the link. It says switch off and on, and no other steps. It didn’t help after trying that. Is the logic board supposed to replaced entirely or repaired. Is there Any links (websites) to get the logic board incase it has to be replaced entirely.
by
@moussihabou - Time to visit an Apple Store or AASP. As the logic board needs repairs.
by
@danj hi, I finally took it an AASP. They told me that they have to change the entire top case because the defective top case would be returned to Apple.
by
Show 3 more comments
Add a comment
Add your answer
Moussihabou will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 25
All Time: 283
