Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Which battery do I need?
Do I need to replace my laptop battery ???
It discharges in about 30 minutes when off the charger.
We have an early 2011 Macbook Pro, 15 inch. Model is A1286. Battery design capacity is 7000 mAh. Full charge I only get about 6190 mAh.
I replaced the battery in 2018. Cycles are only about 90. Battery status is normal whether full charge or down to 7% charge.
Time to change the battery? If so, which one? The only one I found on your site that is close to matching has a capacity of only about 6100 mAh. I need 7000. What is your recommendation? thanks frank
Score 1
Add a comment
1 Answer
Most Helpful Answer
So those are actually really good numbers for a battery that's only five years old. Although we would need some more insight into this. I highly recommend using Coconutbattery, which I shall link here: Coconutbattery. Once you have that installed, take a screen shot of the program and add them to your question. Adding images to an existing question
Score 4
3 Comments:
To add to Jacob answer here’s the needed part MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery and the guide to put it in MacBook Pro 13" Unibody Early 2011 Battery Replacement
by
Thank you for your fast reply. I downloaded coconut and have sent a pic from it to your email. I'm having no luck downloading a pic here. I recalibrated the battery a couple times by disconnecting the charger, draining it down/shut down and than 7 hours later re-connecting the charger. Unfortunately, no change in battery performance.
When I disconnect the charger, the battery goes down to about 84% and than the laptop shuts off automatically. I immediately reconnect the charger , restart the laptop and battery shows 7% charge. What is odd to me is that the battery can go from 84% down to 7% in just a minute or so.
Is the problem a bad battery? IF so , which one do I need? The Macbook pro laptop was manufactured on May 23, 2011, model A1286, 15 inch.
Or is the problem the laptop? Settings are off maybe?
So what do you think is the problem ? Thanks for your help, frank
by
@Retired75th what email address did you send it? I think it got lost!
Review this guide on how to post images Adding images to an existing question
by
Add a comment
Add your answer
Retired75th will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 50
