Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Question Closed
Is the battery that smart?
Here is the info on the battery
Battery Information:
Charge Information:
Charge remaining (mAh): 1176
Fully charged: No
Charging: No
Full charge capacity (mAh): 9940
Health Information:
Cycle count: 1060
Condition: Replace Soon
Battery Installed: Yes
Amperage (mA): -4614
Voltage (mV): 6910
Coconutbattery said i have 9875 mah left now, but this goes down quick
4 Comments
Not sure what you're asking?
by
is the chip in the battery that accurate most of the time
by
Depends on which parameter. The cycle counter I imagine wouldnt be far off. Full charge capacity is likely "programmed" in. The amperage and voltage I imagine is right, it's an uncertainty of just +/-.1 A and +/-.1 V...same as a low-end multimeter. Condition is likely based on cycle count? I would think that the numbers are fairly trust worthy.
by
at this point i have to see if it runs well i guess to be sure
by
Add a comment
1 Answer
Chosen Solution
Nick, I've never seen a battery with this many cycles. It only has about 12% of original capacity. Does it last 10 minutes? Time to change batteries. If you used something besides Coconut battery to get your stats you might try that.
Score 3
1 Comment:
system profiler was off big time, i have 9940mAh left
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 397
