0
Score
nick
12.3k
Asked
Is the battery that smart?
Here is the info on the battery
Battery Information:
Charge Information:
Charge remaining (mAh): 1176
Fully charged: No
Charging: No
Full charge capacity (mAh): 9940
Health Information:
Cycle count: 1060
Condition: Replace Soon
Battery Installed: Yes
Amperage (mA): -4614
Voltage (mV): 6910
Coconutbattery said i have 9875 mah left now, but this goes down quick
2
Score
mayer
121.8k
Answered
Accepted Answer
Nick, I've never seen a battery with this many cycles. It only has about 12% of original capacity. Does it last 10 minutes? Time to change batteries. If you used something besides Coconut battery to get your stats you might try that.
Not sure what you're asking?
Phillip Takahashi,
is the chip in the battery that accurate most of the time
nick,
Depends on which parameter. The cycle counter I imagine wouldnt be far off. Full charge capacity is likely "programmed" in. The amperage and voltage I imagine is right, it's an uncertainty of just +/-.1 A and +/-.1 V...same as a low-end multimeter. Condition is likely based on cycle count? I would think that the numbers are fairly trust worthy.
Phillip Takahashi,
at this point i have to see if it runs well i guess to be sure
nick,
