Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Can battery damage logic board?
Hi guys,
I need "new" battery for MBP early 2011. I found a lots of online for reasonable price, but if I get with cheap one can damage logic board ? I don't need long battery time, but without battery I can use this MBP.
Thanks a lot for any ideas advice :)
Score 2
Add a comment
1 Answer
Chosen Solution
As long as it is compatible with the device you should be good. Although the reason those batteries are cheaper is probably that they weren't certified. I'd maybe look into getting one that says that it has been tested and certified as those can be returned if their happens to be an issue with the battery.
Score 4
5 Comments:
Often these cheap batteries are rebuilds. Basically, a few battery sets are taken apart and the good cells are reconnected into a working battery.
I would stick with a good supplier that risk the expense of a battery which may not last very long.
by
So I should not be worry about get damage my MBP but about lifetime :)
And second question - how long you can store battery (new one - never used) ? And will be OK after several years ? Because MBP 2011 it's bit OLD :D so I am wondering what if I get some X years old one ?
by
@roboscrap I have a good article about that kind of thing here for you. https://www.groovypost.com/howto/store-l...
But to give you the spark notes of it, it depends on the environment it's stored in. You could potentially get it to last years if you keep it in an environment that is 32 °F, dry, and with the battery discharged to around 40%.
by
@jmehnert - I'm still using my 2011 15" MacBook Pro! It's now on its sixth battery and offers what I need for web browsing and answering iFixit questions!
Don't be so quick to dispose of this system as its still better than many of the newer systems!
by
@jmehnert thanks a lot :)
@danj I love this old MBP 2011 mostly because I have old camera and I can control it only from this old machine, this is why I am so worry that can be damage and I will be screwed :)
by
Add a comment
Add your answer
Rob will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 6
All Time: 145
