Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
784 Questions View all
Is a 2.8GHz processor recommended instead of a 2.3GHz?
I just recently panic-ordered a motherboard replacement that turns out I needed.
It’s listed at 2.3GHz and I’ll be completely honest, I’ve never paid attention to my processor and this when ordering, but now browsing back I’ve found…..more powerful processors (2.4, 2..8 GHz etc)? At least that’s how I’d interpret the values.
Assuming no change in other hardware, is a 50% markup with a 2.8GHz processor worth it for a Macbook like this? Or is it just a marginal improvement I might as well just suck it up?
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.3 GHz Logic Board Image
Product
$149.99
Add a comment
1 Answer
Most Helpful Answer
The best way to see the differences between the different logic boards that would work in your system is to use EveryMac web site. Its a bit of work but its a very useful tool! Here’s what it can show you between the early and late 2011 systems (same hardware across)
13” MacBook Pro 2.3GHz vs 2.4GHz Core i5 CPU’s as we can see there is a bit of difference I doubt you notice the differences between these two Core i5 systems as hard as you try. Now lets look at comparing the i5 2.3 vs the 2.7GHz & 2.8GHz Core i7
So its clear there is a more sizable performance improvement between the i5 & i7 chips but between the early and late i7 not as much! So does it make sense jumping to an i7 vs the i5 you have now?
What you are doing with your system has a large bearing here! Writing, reading web pages looking at your pictures or even watching vids I doubt you’ll notice any differences. If you are working on large data sets object graphics, composing music, working on video production then you’ll likely shave minutes in your work flow.
To be honest, the Intel 13” models only use the Intel graphics engine whereas the 15” models offer a discreet GPU so anything graphically oriented will perform much better than the 13” model running the same CPU!
Score 1
Add a comment
Add your answer
Calvin Khan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 377
