Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1625 Questions View all
Camera not detected after moving computer
Hi everyone,
I typically work at a desk, plugged into an external display. As long as I don’t move the computer, my camera works every time I need it (multiple times a week.)
Every once in a while I’ll unplug and take my laptop elsewhere. Most times that I move, when I go to use my webcam for video calls the camera is not detected until I restart my computer. Restarting works every time.
Has anyone had this problem before? Any ideas on what I can do to fix this?
Thanks!
Score 2
1 Comment
Very odd!
Did you try running the onboard diagnostics to see if that popped an error? Restart your system and press the D key. It might not work as Apple messed up the firmware depending on what macOS you are running.
Reference: Mac startup key combinations
by
Add a comment
Chosen Solution
I found a solution! Fixed it every time.
Open terminal and type in: sudo killall VDCAssistant
Score 1
Add a comment
Does this only happen when moving the entire computer? or just if the display on the laptop gets moved? If it’s only when the screen is being moved it sounds like it could be a short in the cable that connects the camera.
1 Comment:
It's only if I pick up and move the whole machine. I can close the screen and re-open it and it works fine.
by
Add a comment
Add your answer
Amber Taus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 67
