Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Questions View all
Strange ram issue that drives me nuts
Hi Fixers,
my beloved and immortal MBP 2011 seems a little bit mortal today, I need some geek help.
Suddenly a crash. Restarted. Another one. And on and on.
It enters in Safe Mode. Disk is fine, no errors.
I have an almost dead battery, ordered here a new one.
I just thought it could be a battery and consequent system-crazyness-apple-stuff.
I had to do some task, so I disconnected the battery in order to go direct on AC.
Wait. Another crash. And on and on.
So entered Single User Recovery: no disk errors here, as it was there.
Tried with AHT: it crashed on checking the RAM.
GOT IT!
I thought. BUT. Here starts the crazyness, listen carefully.
I have 2 banks of 8gigs. With both of them I got continue crashes on boot.
…any different slot and banks combination works like a charm. So the problem is not upper or lower slot or is not bank1 or bank2 of mine.
This happen with or without the battery pack connected to the Mac.
This is the point when I need some help: could it be a dual channel problem? What can I try to do?
Another cool weirdo behaviour: as you may know when you go without battery the fans are always full speed. They are full speed only before crashing: with the single bank (1 or 2, up or down slot) fans are working as battery was plugged.
Thank you in advance for your time!
Stefano
Add a comment
1 Answer
The RAM carrier could be warped, Sometime losing thr screws a 1/4 or 1/2 turn can help. Also make sure the latches are holding. I’ve wedged tooth picks (don’t laugh!) to help press the latch. Others have used small pieces of credit card stock.
Also I give the contacts a good wipe with a new soft pink pencil eraser just to make sure the surfaces are not tarnished.
I would start there, If you still have issues I would replace the HD SATA cable this is important if you have a SSD installed as the original HDD’s this series has was only SATA II (3.0 Gb/s) whereas the newer SSD drives often run SATA III (6.0 Gb/s) and unlike the HDD the data flow is much faster so any errors in the cable can mess the data transfer! Your Hard Drive Cable Is A Ticking Time Bomb
Add a comment
Add your answer
stefanospada will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 25
