Score
Avatar
Jessica Holst
13
Asked
Why is the fan so loud?
History
The fan on my iMac Intel 27" is so loud and I wonder how to fix it
Edited by
Do you have any other symptoms other than a loud fan? What are the last three numbers of your serial number?
rj713,
is it just loud or is it screeching?
mayer,
Post Answer
Score
Avatar
Country Computer Service
1.3k
Answered
PermalinkHistory
I wouldn't just drop lubricant on the fan. If the fan is clogged with dust or nicotine it will slow it down even more.
If you can access the fan use some 91% (or 91-99%, do not use anything with a lesser percentage as they can be conductive and if accidently dropped onto a system / logic board can cause electronic components to short out) Isopropral (rubbing / the white NOT green stuff) alcohol and a brush to clean away the dust and debris then add about 2 drops of 3 and one oil down in the center where it gets inside of the fan housing.
If it still makes noise, you probably have a bearing going out - these fans spin hundreds of revolutions per second and will simply wear out ... in this case, replace it, the fans only cost a few bucks.
When your in there also use something like a tooth brush, with a dab of alcohol ^ mentioned above to clean off any dust on the exhaust vents.
Country Computer Service,
0
Score
Avatar
ray
25
Answered
PermalinkHistory
give it a good oiling with some grease ..don't use WD40 it good but lasts only a few days ..give it a good clean as well.
0
Score
Avatar
zionthelion73
Answered
PermalinkHistory
Maybe the fan is heavier because of the dust on it
Add Your Answer
