Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Questions View all
I get chime, fan and then system reboots on its own
I just got a 2011 15” MacBook Pro and works as described,
When I plug the batt., I get the chime, fans spin, white screen, (no keyboard light) and after some time (+- 20 seconds), the system reboots, (chime) and then shut off.
Only boot if I plug the batt. or magsafe…
This happen with no SSD, with SSD (Sierra with GPu disable), bootable USB etc….
Can it be the Keyboard?
Can I unplug the keyboard connector from motherboard and try with external keyboard? Or should break for parts?
Add a comment
Chosen Solution
With the drive installed & connected, MagSafe disconnected and battery removed, press the power button and hold it for a good 15 sec to fully discharge the logic board. Now plug in the MagSafe and quickly press the Shift (⇧) to enter into Safe Mode. Are you able to get that far? What do you see on the screen.
Reference: Mac startup key combinations
Score 1
1 Comment:
Thanks and sorry for my delay (miss the notification)!!
It´s a Keyboard problem, I unplug the flex in the motherboard, and the mac is running ok with a external keyboard!
by
Add a comment
Problems!!!
Don´t know correct position….
(it´s from the keyboard flex)
1 Comment:
It looks like the folding compression latch has come off the logic board base. It you look you should see a small pin on each side this is the hinge pin =which sits into the mating slot in base piece. Carefully bow the part just enough to get into the the correct placement. Review Step 20 in this guide MacBook Pro 15" Unibody Early 2011 Logic Board Replacement
by
Add a comment
Add your answer
Paulo Santos will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 38
