2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
silence when I reboot into High Sierra
Have the same problem on a 2010 white plastic macbook running high sierra.
Nothing I found on line worked. Then one day I booted it from a Linux Ubuntu install USB stick and the sound worked fine all the whie that OS was booted so mine is not a hardware problem.
It went back to silence when I rebooted into High Sierra. Does that tell anyone here what needs to be fixed on mine? thanks djc
2 Comments:
Did you try a smc reset
by
Once a day for weeks
by
Add a comment
1 Answer
Apple killed the startup Chime on you! Here’s more on it How to resurrect your Mac’s startup chime
2 Comments:
Chime always worked but no sounds afterward.
by
Lets clarify things your issue is not the startup chime, its your lack of sound after boot (no music, podcasts or videos) is that correct??
by
Add a comment
Add your answer
djcopely will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 48
