Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
592 Questions View all
Laptop dies when unplugged
I replaced the battery in this MBP just over a year ago. It now shuts off immediately when unplugged and Coconut Battery registers no battery at all.
Does this indicate a faulty battery or a logic board problem? The latter seems more likely to me, but I’m asking because a battery for another computer of the same model that I ordered from iFixit around the same time last year also recently turned out to be faulty.
2 Comments
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by
Thanks Dan. Just added the CoconutBattery shot.
by
Add a comment
Chosen Solution
Sadly your battery is bad! The micro-controller within it has failed so the communication to your system is not working as well as the charging of the battery.
Time to replace it! I would contact the seller to see if they offer a warranty. As an example iFixit offers a year.
Score 1
Add a comment
Most Helpful Answer
Try replacing the battery again. If that doesn’t do the trick, that is when you should either replace the logic board or the whole MacBook altogether.
Score 1
1 Comment:
Let's first diagnose the issue before we go that far!
by
Add a comment
Add your answer
thardee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 47
