Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
Will my mid 2007 iMac support this CPU?
I have been looking to upgrade my mid 2007 iMac with a better CPU suited for heavier tasks.
In search for a CPU that would fit the criteria of a CPU that would fit the iMac’s CPU socket type and design, I found an Intel Core 2 Extreme X9100 3.06GHZ/1066MHZ (SLB48 Socket P/PGA478 CPU on eBay for about $40.
If you want more info on exactly which CPU I am talking about INTEL Core 2 Extreme X9100 in case you want a better idea of what I am talking about here.
All I want to know is whether or not if the my iMac can take it as a CPU or whether or not I need to do a Firmware update beforehand to make it work.
Thanks!
2 Comments:
Here's r seems series A1224
Here's the one system that used the X9100 chip 24" iMac 2.8GHz Core 2 Extreme
by
Your comment makes no sense
by
Add a comment
1 Answer
While the system can support the chip, I don’t think you will get enough performance benefit. You are still limited to the applications you are currently using.
Make sure you are running OS-X El Capitan (10.11.6) which is the highest your system will support.
4 Comments:
As a matter of fact, I ALWAYS run macOS 10.11.6 on it. Another thing I thought I would mention that I forgot to mention in the description is my iMac only has a 2.4 GHz Intel Core 2 Duo, so the core 2 extreme might be a significant upgrade because I am trying to modern apps that support higher processor speeds.
by
@duccmann - What apps are you thinking of ?
by
Final cut pro X, Games from steam like terraria (because terraria requires a better cpu than the 2.4 GHz CPU I have now), possibly pro tools because I own a license to it, amongst other things.
by
@duccmann - You need a bigger boat! Famous 'Jaws' quote.
Sadly, the Core 2 Duo are still not powerful enough you really need an i Series CPU and given the Final Cut Pro and gaming the GPU this series has won't cut it either if you are working on anything sizable or heavy graphical.
Sorry ;-{
by
Add a comment
Add your answer
Evan C will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 9
All Time: 152
