Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
iMac not Recognizing CD Caddy
Hi, I recently installed a PATA CD Caddy for my Early 2008 iMac, it only spins up and nothing detected on macOS or Windows, tried to PRAM and SMC Reset but nothing happened, even tried use the Jumpers on the SATA Drive, but nothing, just spins up, please help me.
Add a comment
1 Answer
Most Helpful Answer
Are you sure you got the correct one? Ultra ATA/100 (operates at UATA/33 or UATA/66)
Pioneer DVR-K05 slim dual layer Superdrive, Apple P/N DVR-K05PA
You don’t need to alter the SATA drive
Score 1
4 Comments:
So i need to remove the jumpers from the sata drive?
by
and how to check if i got the correct one?
by
@supermememaker2 - Leave the SATA drive alone!
Playing with the TV antenna cable won't change the fact the AC cord is not plugged in ;-}
Guess you'll need to get another unit and you might want to get a new cable set as well.
by
oh ok, thanks for helping! ill get a new CD Caddy and new cable?
by
Add a comment
Add your answer
Macix26 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 12
All Time: 66
