2
Score
Avatar
vgp916
35
Asked
LCD Panel replacement because of intermittent backlight
History
Same story that's probably been told 500 times, my backlight intermittently works. The screen looks fine when using a flashlight, and plugging in an external monitor works perfectly fine. The backlight will come on if you repeatedly toggle the brightness buttons on the lowest setting and will stay on for 10-40 seconds unless you bring the brightness up real high, in which case it goes out immediately.
I've replaced the inverter, and I've replaced the inverter cable. Same results.
So it seems like I have three options, from cheapest to most expensive:
1. Replace CCFL
2. Replace backlight assy (I assume he means assembly? recommended here)
3. Replace the LCD Panel
Seems like replacing the CCFL is incredibly complex so I won't bark up that tree.
So I'm left with either buying a cracked panel on ebay to try and extract and replace the assy, or just purchasing an entire new LCD panel.
So my questions are:
#1 - Given my symptoms and what I've done so far, could I be confident an assy replacement or panel replacement would fix my issue (if it's not the inverter or inverter cable, it seems like the only other possible thing would be the logic board. But an external monitor working fine should negate that, right?)
#2 - If I go the route of buying a cracked screen and replacing the assy, how difficult/obvious is that?
#3 - If I go the route of replacing the LCD panel, does it matter which kind? My research shows there are four kinds of displays. I have a LTN133W1. iFixit doesn't mention which one they sell. Am I OK buying any of the four, or do I need to replace mine exactly?
Thanks for your help!
Edited by
Product Image
MacBook 13.3" LCD Panel
LCD without the display bezels, hinges, hinge mount or cables / 1280x800 LCD / 13.3" — 35 available at 149.95 each.
Post Answer
2
Score
Avatar
mayer
121.8k
Answered
Accepted Answer
PermalinkHistory
Replace the LCD with EXACTLY the same model.
Did this and now it's working great. Thanks for the advice.
vgp916,
Some times the answer is short and simple ;-) Glad I could help.
mayer,
Add Your Answer
