Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2398 Questions View all
How to remove a stripped screw from near the vibrator motor?
Whilst trying to disassemble my Iphone 4G to replace the Digitizer & LCD screen i have managed to find and probally strip a tiny screw.
This screw is located near the Vibrator motor just above where the battery sits.
I have tried using a flat rubber band to give grip and even a larger screwdriver with pressure to create it after listening to suggestions - neither of these ideas have worked! what can i do? i've heard that a dab of superglue on the screw head and setting a screwdriver to it should work? is this true would it help or is there something else i can do to get the screw out.
please it is urgent as i need my phone.
Score -1
1 Comment
I haven't gotten a new screw but I've just ordered a new vibrate motor as the connection without the screw isn't strong enough to activate the vibrate all the time. So replacing the whole thing since I bent the bracket :-)
Thanks again for the help
by
Add a comment
Most Helpful Answer
I would try the superglue trick since it seems you are in a hurry. Use a small phillips screwdriver and a drop of more thick running glue. Do not use the type that flows smoothly or you could end up gluing even more than you want.
Here is some advice: http://www.todayifoundout.com/index.php/...
Take your time and move slowly. A Dremel could be your rescue but be careful so you don't damage more.
Score 2
4 Comments:
Camera screws are similar. Here may be some help: http://www.ehow.com/how_5718712_remove-s...
by
I drill them out..very carefully! works for me.
by
Thanx for the suggestions the glue didn't work
And I was too scared to drill it out.
I ended up using tweezers n bending the bracket to be able to access the screw for the new LCD n digitizer and when I pushed the bracket back into place the screw just popped out ( go figure)
My phones all back together now n functioning fine :-)
by
Did you get a new screw or just leave it? Kudos to you for not giving up Jeannie ;-)
by
Add a comment
You can try this but i must warn you to be VERY CAUTIOUS in what you are doing. I used this method and it was successful for me, but then again, it was a small screw. *I am not responsible for any damage done to your phone* :)
Ok, so i took a power drill and used it on the top screw of the EMF protection shield. The screw was stripped so I took the smallest drill bit i could find that would just fit the circumference of the screw. Then, very carefully screw into it, completely making the screw into a bowl. Next, switched directions of the drill, used a little force and went slow....next thing i know the screw is out. You can try this but just be careful and don't break anything. GOOD LUCK! Let me Know if you need anything else. PLEASE be careful
Add a comment
Add your answer
Jeannie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 2,592
