1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Questions View all
Why is my hard drive not recognized?
I installed a crucial MX500 SSD on my 17" iMac Core Duo computer. I created a bootable USB for macOS X Catalina. When I start up the computer holding down the option key, an image that says “Install macOS Catalina” appears and after clicking it, nothing happens. I waited all night and nothing.
Please help.
Thanks in advance.
Add a comment
1 Answer
Chosen Solution
The EMC 2104 is limited to
Pre-Installed MacOS:X 10.4.4 (8G1165)Maximum MacOS:X 10.6.8*
Go here and look up your machine and it will tell you the highest operating system your machine will take.
https://everymac.com/ultimate-mac-lookup...
Score 2
2 Comments:
Thanks a lot! I'll try it and let you know.
by
@ruvelsa - Sadly the Crucial MX500 SSD won't work in your system as the systems SATA port is only SATA I (1.5 Gb/s) You'll need to use a Samsung 860 EVO SSD unlike the Crucial drive which is a fixed SATA III (6.0 Gb/s) the Samsung is auto sense so it will dial down the data rate to what the system can support in this case SATA I (1.5 Gb/s).
by
Add a comment
Add your answer
Ruben Velez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 64
