Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
no video on the screen 3 diagnostic led every on?
hi
i have one imac a 1224 and non video on the screen
The diagnostic led on the logic board are
1on, 2 on 3 on but there isn't install the video card
because the led 3 is every on
my logic board is dead?
please answare me
dear Silvano
Score 1
Add a comment
Chosen Solution
LED Startup Sequence
LED #1 = Power available.
If no LED is visible:
• Verify AC source
• Verify known-good AC cable is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
LED #1 + LED #2 = Power available, and system is powered on.
If second LED is not visible when power button is pressed:
• Verify power button connection to logic board
• Verify power button functionality
• Verify logic board
LED #1 + LED #2 + LED #3 = Power available, system is powered on, and video card found.
If third LED is not visible after power on:
• Verify that MXM video card is seated properly
Score 4
1 Comment:
Hook it up to an external monitor with the video card in and see what you get.
by
Add a comment
hi
but on my logic board the led 3 is every on when i press the power button
but the video card isn't install?
thanks Silvano
1 Comment:
so, you are saying that you do not have the videocard installed on the logic board and the third LED is coming on. then your logic board is possibly dead. if you install the video card, does LED 3 come on? do you see video?
by
Add a comment
hi
if i install the video card on the logic board
the led 3 is on but there isn't the video on the screen.
dear Silvano
1 Comment:
sorry for the delay. i would recommend replacing the logic baord at that point.
by
Add a comment
Add your answer
silvano will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 845
