Repair guides for the MacBook.
3787 Questions View all
Battery is Not recognized - Shows (X) out in Menu Bar
I have a White 13" Macbook. The battery is no longer working. It shows as X'ed out in the menu bar. When i plug in the Power cord it goes Green immediately. It does not charge the battery at all. The laptop runs fine off the Powercord but dies if i unplug it. I tested the power cord and battery on a similar macbook. So it seems that it would be the computer. I did try and replace the keyboard before this all when down but the battery was fine or a week or 2 before it went X'd out. Does this sound like it could be fixed by replacing the "Batter Connector" or a Logic Board issue? Reading the posts it sound like if the computer works then it would not be a logic board issue?
Any thoughts?
Thanks
Aaron
Score 5
3 Comments
Is the X red or black?
by
The X is black
by
Wouldn't it show up as an X on a different laptop if the battery was bad? I put it on a similar laptop and it starts charging just like normal and shows up in the task bar without the X.
by
Add a comment
Chosen Solution
Here's our previous answer on this: Black x in the battery charge symbol?
Score 3
Add a comment
Check in sys profiler about cycle count.
Must be battery gone.
Add a comment
Add your answer
Aaron Brock will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 13,164
