Battery not charging, SMC reset is not helping
My Magsafe power adapter is stuck on green light, battery is not always charging. I’ve tried unplugging and plugging back battery and SMC reset. Sometimes it helps, but battery gets stuck usually around 60-70% if I disconnect the adapter Macbook turns off and it will not turn on without adapter. It seems to work normally if battery is between 80-100% anything below shows green light on adapter and if I’m lucky SMC reset will work. Battery was replaced and worked for like 8 months. It shows 177 cycles and “normal” status. Here is snapshot
2 Comments
Install this gem of an app CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by Dan
Hey, what worked for you in the end?
by maaas
