2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Water spill, has my logic board been damaged?
I spilled water some water which got inside my macbook.
I stupidly turned it on after spilling the water. It came on for a few seconds and then went off. I have removed the back cover and battery and I am letting it dry under a light. Is this the best thing to do and will my computer work again?
1 Comment
Don't know if this helps but when I tried the green light was coming on on the magsafe adaptor
by
Add a comment
Chosen Solution
Your computer probably wount work anymore cause it was turing itself off for a reason
But the best is to wash logic board with alkohol or something from the guide to replace water and prevent corrosion
dry up to 48h
plug in and see for yourself, might get lucky and no corrosion in furure (:
Score 1
1 Comment:
Would rather not remove the logic board as I do not have the necessary tools. As The liquid was just water, will it really be very necessary to clean the logic board?
by
Add a comment
Most Helpful Answer
Here's the guide on taking care of liquid damage: Electronics Water Damage
Score 2
Add a comment
Add your answer
Wilson Luke will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,083
