Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Questions View all
Front panel black border materlal between plastic sheet and steel
What material does Apple use for the black border on the front panel between the plastic sheet and the thin galvanized steel? What coating or surface treatment do they use that both bonds to plastic, and provides a surface for a strong adhesive bond to galvanized steel?
2 Comments
Do you have a photo to help explain what you mean?
by
I agree I'm not sure what your question is. Please post a few pics so we can see Adding images to an existing question
by
Add a comment
1 Answer
Most Helpful Answer
OK now I have a better idea what your question is. The cover glass is painted with a coat of dense paint so if you’ve damaged it it’s not easy to patch as the shade of black might not match up. Here’s the part number for the cover glass if you want to just replace it: iMac Intel 20" EMC 2266 Glass Panel, Apple P/N 922-8848
Score 1
Add a comment
Add your answer
Jason will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 7
All Time: 42
