0
Score
Avatar
mahendra
Asked
Error 3194
History
i have iphone 3gs and i have been follow your guide lines but,... now my iphone stuc on recovery mode and my itunes has message stop working and error 3194.
please help..
Edited by: oldturkey03 ( )
Please start a new question so that others will see it. This is an old answered question and very few will even look at an answered question.
mayer,
mahendra, check this question http://www.ifixit.com/Answers/View/52104... and see what Brad is saying. Probably your best bet. here is part of the explanation "Lots user who were downgrade iOS 4 to 3.1.3 have been facing a iPhone Restore Error Code 3194 which occurs when users try to restore to iOS 3.1.3 firmware from iOS4. But what is this error all about? Well, Apple always signs the latest firmware not the prior one and while downgrading to previous firmware the 3194 error will come if you have not saved or taken backup of ECID SHSH blobs of previous firmware. Details: http://thetechjournal.com/electronics/ip... "
oldturkey03,
Post Answer
0
Score
Avatar
Brad
8.4k
Answered
PermalinkHistory
Error 3194 is usually because SHSH were not available to iTunes during the restore. But if you are at Recovery Mode you can always try program TinyUmbrella to allow it to try Exit Recovery button. If that does not work. Then you must restore and allow SHSH to be used. If you are going with stock firmware 4.3.3 then you can allow iTunes to do everything for you. But you must make sure you are not blocking Apple from signing the firmware with Apple SHSH. Therefore use TinyUmbrella program, go to "Advanced" and make sure there is "no check mark" in the box "set hosts to Cydia on exit". Again no check in the box. If you don't want to use TinyUmbrella, then search for your computer Hosts file and make sure there are no lines with numbers and gs.apple.com (this is the blocking Apple line), delete these lines entirely. If your Hosts file is clean then let iTunes restore for you. If you have iPad baseband then you will need to restore with Custom Firmware, Pwned DFU and possibly help from TinyUmbrella.
0
Score
Avatar
blackboxiphone
Answered
PermalinkHistory
I wrote a short guide that explains how to fix error 3194:
http://blackbox-iphone.com/index.php/how...
Add Your Answer
