13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
575 Questions View all
MacBook fan in constantly running loud, battery not showing
Hi everyone,
I’m stuck with a macbook unibody late 2008 with a huge problem.. The fan is constantly running loud from the moment i power it up, the magsafe light is dim green, the battery don’t show at all.. each time i have to (unplug the magsafe hold the power button for 5 seconds plug the magsafe while holding for an other 5 seconds release the power button and power up) in order to power up my mac, and it shuts down every time i unplug the magsafe… help please?
Add a comment
1 Answer
Chosen Solution
It sounds like you have a couple of different problems!
The first is your battery & the charging logic is likely in bad shape. Lets run this app so we can see things more clearly CoconutBattery Lets get a snapshot of the main window with the MagSafe connected. Post it here for us to see Adding images to an existing question
The racing fan is the SMC trying to manage an overheating condition, at least thats what SMC thinks. This could be caused by liquid damage or a failed sensor. To investigate this weill need to us a different App TG Pro is what I would use as it allows us to see things more clearly. Again, take a snapshot of the main window showing all of the sensors (you may need to grow the window) and past it here for us to see.
Lastly, physical inspection to see if any corrosion or dust build up needs to be cleaned up. Get a small soft pain brush and a can of can’ed air so you can scrub down the dusty parts and us the can’ed air to blow the debris off. Given the systems age you should clean off the old thermal paste and apply fresh paste. So here’s the guide to fully remove the logic board to inspect it (both sides) MacBook Unibody Model A1278 Logic Board Replacement and here’s the info on the thermal paste How to Apply Thermal Paste
Electronics Skills Image
Guide
Difficulty:
Moderate
5 - 20 minutes
MacBook Unibody Model A1278 Logic Board Image
Guide
Difficulty:
Difficult
2 - 4 hours
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Add a comment
Add your answer
Hechem Mihoubi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 11
All Time: 661
