A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
565 Questions View all
Bent display lid from fall
Hi everyone
I just dropped my brand new MacBook Pro. The display lid is bent in the corner! :(
How can I fix this any ideas?
I already tried this but it didnt work :( Macbook Hinge Scraping / Scratching Problem - Quick and Easy Fix!
Thanks everyone.
Score 1
Add a comment
Most Helpful Answer
you don't want to risk that lcd for just trying to unbend.
Score 1
3 Comments:
Actually youre right i dont want. But if is there any quick solution i would give it shot. Im glad screen work perfectly except that light.
by
The light in the corner is caused by the compression of the LCD panels as the liquid crystal material is being squeezed.
by
Can use like this or should i change panel immediately?
by
Add a comment
Many a sin can be covered over using a good protective case. I really like these:
https://www.ebay.com/itm/Rubberized-Hard...
If you just can’t stand it, you can get one from PowerBook Medic for $650
http://www.powerbookmedic.com/MacBook-Pr...
I will be listing this part (a working pull) on eBay tomorrow for just under $500.
Pricey isn’t it!
Score 1
1 Comment:
I ordered one protective case. I hope it will fit to my bended screen.
Thanks.
by
Add a comment
The problem you face here is any reshaping of the lid frame puts the screen at risk of damage. The only solution is to replace the lid assembly which is quite expensive!
Sorry ;-{
4 Comments:
by
I would live with it
by
Ill do the same. Thank you.
by
Did the yellow discoloring worsen over time?? I dropped mine today and have the EXACT same issue :( fixing it will cost the same amount i bought my laptop for and wanna know if i can leave it how it is without it getting completely messed up.
by
Add a comment
@fredy12 Did you got repaired ? because I am having the same issue
Add a comment
Accidentally hit the top left of my laptop screen onto a chair. Bent but no damage to screen. Only the screen has bright spots. ;(
Add a comment
I have this problem right now with my MacBook air m1. Did you ever get it repaired/ did it end up causing further problems?
Add a comment
Add your answer
Ferdi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 39
All Time: 4,792
