Score
Avatar
Chris Green
14.9k
Asked
Which Power Supplies Are Compatible?
History
Earlier today, I picked up a broken PowerMac G5 from a flea market. It's a dual 1.8Ghz model from June 2004. (A1047) The unit wouldn't turn on, so I figured that it had a dead power supply. I confirmed this later, by modifying an ATX (PC) power supply to run the computer. It boots up with the modified ATX PSU, so I'm planning on buying a replacement for the original. The original power supply is a 600W AcBel. I've seen a few different wattage power supplies on eBay, and want to know if I can use a 450W unit (Somewhat cheaper than a 600W) instead. Would this be possible, or would I need to buy a 600W PSU?
Edited by
Post Answer
2
Score
Avatar
mayer
121.8k
Answered
Accepted Answer
PermalinkHistory
You'll probably be alright unless you start loading it up with PCI cards and a lot of extra RAM. Hopefully you got the original system installations disks that have the fan syncing software (this is needed when changing any major component.
I might have a set of disks laying around. if not, then I'll just buy a set. I'm probably just going to sell it, so I'll get it up and running.
Chris Green,
Score
Avatar
Richdave
5.1k
Answered
PermalinkHistory
If your system has a 600W PSU then I suggest that's' what you need to replace it with.
Add Your Answer
