Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
784 Questions View all
loose connections of Thunderbolt and USB ports
Happy Holiday to everyone !
At least one of my USB ports seems to act up every now and then. Recently my Thunderbolt port also is acting up (which I mainly use to connect an external monitor) loosing connection on a regular basis, mainly when I somehow “touch” a cable or even the keyboard. Very rarely the monitor will also display a scrambled picture.
All of that seems like a loose connection on the logic board?
I have not opened the Macbook yet (will do so shortly to replace RAM).
Any thoughts short of changing the logic board ?
Thanks in advance
Dirk
Add a comment
1 Answer
Chosen Solution
Sadly nothing you really can do with the ports. As you can see here the ports are soldered to the logic board and have shields around them.
You might bend the outside shell springs a bit but thats about it.
Score 1
4 Comments:
thank you Dan and a Happy New Year !
I will try to bend the springs and see what happens..
by
@dirku - Same to you! Be safe in your travels!
by
@dirku I’ve got the same problem. What happened when you bent them back up?
by
@lechi - I'm sure @dirku solved his issue as he accepted the answer back in Jan 2019!
by
Add a comment
Add your answer
Dirk U will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 2,449
