0
Score
Avatar
Patrick
11
Asked
Where is my processor speed located?
History
Hi,
I can't seem to find the location or any info regarding the processor speed on my iBook g3. Because there were so many models of this particular Mac made, I don't know specific year, but I do know that it has 2 USB and 1 Firewire port(s), and from the research I've done, I think it's late 2001? Anyway, it runs OS 9.2, I'm trying to update to 10.4, but the cd drive no longer works, and the keyboard connector to the motherboard is busted (both easily fixable), but I can't until I know processor speed. I've gone through utilities, and have found processviewer, but something is wrong with the app. I have also tried "About this Mac" but nothing. Any ideas? Should I just replace the hard drive with a 160 gb that has 10.4 and re-install it?
thanks for your help!
-Patrick
Edited by
Post Answer
Score
Avatar
mayer
121.8k
Answered
Accepted Answer
PermalinkHistory
Go under the Apple (upper left hand corner) to either About this Mac or system profiler and it will tell you exactly what Mac you have.
what it tells me in about this mac (or about this computer as it says) is: version-Mac OS 9.2.2 Mac OS Rom 8.9.1 Memory 128 MB, Virtual Memory 129 MB on Disk, Largest unused block 97.1 MB what it says in system profiler ...upp..found it.
Patrick,
Score
Avatar
rj713
33.9k
Answered
PermalinkHistory
Hi Patrick, All iBook G3's except the very first will run 10.4 if you have enough memory. The deciding factor on using the drive with 10.4 on it is was the OS installed on a PPC computer? If so I would go ahead and try it. If it works you can find the cpu speed by clicking "about this Mac" and then the more info button. None of this will work however if the drive was loaded from a Intel unit as they use different formats.
Edited by
Becuase I picked this up from a school district, I have no idea as to the status of os 9 being loaded from a ppc computer...the drive doesn't open either way, so I'm thinking I'll have to replace that. Another option I'm considering is taking a 120 gb hdd, which is the limit for this type, putting it in my 08 MacBook and installing 10.4 that way and then installin it in the iBook that way...think it would work? It would give me time to get the combo drive and fix the keyboard problems
Patrick,
No the PPC and Intel CPU's require a different format and are not compatible with each other. You would need to use a PPC computer to format and install 10.4 for it to function in the G3. The OS copies for the two have differences also.
rj713,
This computer is a power pc...I believe my other model is intel based...so now I know I need to fix the disk drive before I can reformat..oh well, it's just money!
Patrick,
0
Score
Avatar
Chris Green
14.9k
Answered
PermalinkHistory
Remove the keyboard. Underneith, there should be a sticker that should have info that looks something like this: "***MHZ/128MB/40GB HD/AIRPORT" "***Mhz" would be the processor speed, unless someone has changed the motherboard. It should be 500Mhz, 600Mhz, 700Mhz, 800Mhz, or 900Mhz.
Nope, no sticker. And it's not in the battery bay either. I picked this up from an old school district, so it is possible it was at one point removed. Any other suggestions?
Patrick,
Add Your Answer
