Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1626 Questions View all
MacBook Pro will not turn on
My MacBook Pro suddenly stopped working. It will not start up and the screen remains black, no chimes or any loud noises.
The battery test button works and lights up when pressed. When trying to power on, the power indicator light will turn on for a sec before it goes off instantly.
My system has no water damage and has not experienced great damage from dropping. But! It has been through some high temperatures, graphic design & interface work, and light gaming.
Been searching around for similar problems, and have tried resetting but nothing will work for me.
I want to understand the problem and try to fix it, but I’m really close to selling it (if possible) That is if the issue is just impossible for me and costly. Thoughts?
Score 1
Add a comment
1 Answer
Chosen Solution
You are in a pickle! Sadly, it does sound like your logic board has died.
You didn’t state it but I think you’ll see your MagSafe plug is glowing green and your battery checker LED’s (8 of them) are all lit and steady. If I’m wrong please correct me.
This series does not have a dedicated graphics chip which would be beneficial working in graphic design. None of the 13” Unibody or Retina series offered dedicated GPU’s. If you are doing deep and large drawings I would recommend you get a 15” with a dedicated GPU. If you are just doing small to medium sized simple line drawing or shallow colored drawings you likely will get away without it.
So what to do? Here’s the IFIXIT guide to replace your logic board: MacBook Pro 13" Unibody Mid 2012 Logic Board Replacement as you can see its a bit of work. Here are the two possible logic boards MacBook Pro 13" Unibody (Mid 2012) 2.5 GHz Logic Board & MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board
Jumping to a newer system will be costly! Even another Unibody model. If you can find a 15” 2012 model I would jump onto it as you will be much happier in its performance and you can swap out your RAM and drive over if need be.
If you find the older display is lacking then jump to a 15” 2013 or 2014 retina model but that would be the most costly and you need to buy the larger RAM (16 GB) upfront as its soldered to the logic board.
MacBook Pro 13" Unibody (Mid 2012) 2.5 GHz Logic Board Image
Product
$249.99
MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board Image
Product
$299.99
Score 1
Add a comment
Add your answer
Ann Soriano will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 93
