Score
Avatar
rchinatti
13
Asked
how do you reconnect headphone cable
History
I was able to take apart my old ipod iphoto and replace the battery in it. However, I can't seem to get the heapdphone cable to reconnect on the reassembly end. Did I bend something? Can I fit it? Help!
Edited by
Post Answer
Score
Avatar
QEII Student IT
3.5k
Answered
PermalinkHistory
I suggest you check iFixit's Guide for that repair
Also you could look at this one
Edited by
Score
Avatar
David Iwanicki
2.7k
Answered
PermalinkHistory
compare the orange cable end to the photo on step 9 here:
http://www.ifixit.com/Guide/Repair/iPod-4th-Generation-or-Photo-Headphone-Jack/388/3#s1633
Is the square black connector still on the end of the orange cable? If not, then you accidentally peeled the orange cable off of the connector, which is still in its socket on the logic board. You will need to order a replacement headphone jack board, and use tweezers or needle nose pliers to GENTLY remove the damaged black connector square from the socket on the logic board.
If the cable and connector are intact, it should be a simple matter to snap it back into the socket on the logic board - the cable routing will guide the connector to the socket with the correct orientation.
Add Your Answer
