Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
592 Questions View all
Trackpad cursor moving around on its own and clicking anywhere
Hello.
I own a Macbook Pro Late 2011 model and recently the trackpads cursor is behaving weirdly, like it moves around on its own, it clicks anywhere.
I am guessing I need to change my trackpad ?
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Will the trackpad on above link help me ? Do I need to check model number A1278 ?
or just 'Mid-2009--Mid-2012' is good enough to assume it will work with my laptop.
Thank you
Update (07/16/2018)
even the vertical page scrolling sometimes does not work
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad Image
Product
$59.99
Score 1
2 Comments
the cursor erratic behavior seems to have stopped today but the 2 finger scrolling is not smooth, sometimes I can not scroll.
and then it works smoothly.
Using the coconutbattery app I found out that MBP battery had 1643 cycle count.
by
Sounds like you have two problems here! A battery which also needs to be replaced. As you can see here you've exceeded its lifespan! Determine battery cycle count for Mac notebooks
by
Add a comment
Chosen Solution
Before buying a new trackpad I'd open the Mac and make sure the battery is not swollen. A defective battery might push on trackpad and cause the symptoms you're experiencing.
Score 2
3 Comments:
by
I checked with a vendor. The battery does not seem to be swollen.
Can't we figure out if the battery is swollen without opening the mac ?
by
No, not possible, it needs visual inspection. You just need a small philips screwdriver to open the bottom, your fingers to unplug the battery connector, and a tri-winged screwdriver to remove the two battery screws. It just takes 10mins to do all.
by
Add a comment
The part you need is part number 922-9063 which is what the link you have is, you’re good to go!
Here’s the IFIXIT guide you’ll need to follow: MacBook Pro 13" Unibody Late 2011 Trackpad Replacement
Score 1
Add a comment
Add your answer
jiten shah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 1,872
