1.83, 2, or 2.16 GHz Core Duo processor
281 Questions View all
Shorted out inverter cable...test connector vs logic board damage?
MacBook Pro 15" Core 2 Duo Model A1150
Put the wrong back panel screw (fit but too long) during reassembly and shorted out the inverter cable. Smelt smoke upon startup, shut it down, removed screw, restarted. Now I have a very dim display and a stinky logic board (at respective connectors). I know I should replace the inverter cable, then inverter board, but if those fail, I've wasted >$75 and then have to move on to testing logic board connectors... can I try this step 1st? I have a bad feeling I've fried the connector, meaning I'm screwed. How do I test the connectors/logic board? Voltmeter at pins?
thanks a bunch!
Score -1
Add a comment
Chosen Solution
This is the cable you most likely need: MacBook (Core Duo/Core 2 Duo) Inverter Cable
To be sure please give us the last three letters of your serial number. It's $18.95
MacBook (Core Duo/Core 2 Duo) Inverter Cable Image
Product
$19.99
Score 3
Add a comment
Hi Jeff, Did you get your issue fixed? I have a similar problem.
Add a comment
Add your answer
Jeff Bennett will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 1,857
