0
Score
Avatar
Jeff Bennett
Asked
Shorted out inverter cable...test connector vs logic board damage?
History
MacBook Pro 15" Core 2 Duo Model A1150
Put the wrong back panel screw (fit but too long) during reassembly and shorted out the inverter cable. Smelt smoke upon startup, shut it down, removed screw, restarted. Now I have a very dim display and a stinky logic board (at respective connectors). I know I should replace the inverter cable, then inverter board, but if those fail, I've wasted >$75 and then have to move on to testing logic board connectors... can I try this step 1st? I have a bad feeling I've fried the connector, meaning I'm screwed. How do I test the connectors/logic board? Voltmeter at pins?
thanks a bunch!
Edited by: mayer ( )
Post Answer
2
Score
Avatar
mayer
150.7k
Answered
PermalinkHistory
This is the cable you most likely need: MacBook (Core Duo/Core 2 Duo) Inverter Cable
To be sure please give us the last three letters of your serial number. It's $18.95
Product Image
Connects the logic board to the display inverter. — 6 available at 19.95 each.
0
Score
Avatar
francois
13
Answered
PermalinkHistory
Hi Jeff, Did you get your issue fixed? I have a similar problem.
Add Your Answer
