Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
592 Questions View all
Do I need to condition new iFixit battery?
After much research and internal debate, my battery purchase came down to Apple in-Store replacement, OWC or iFixit. I went with iFixit and ordered today.
I noticed that there are specific "conditioning" instructions on the OWC site where you charge and fully drain to condition the battery.
Will I need to do any of this for my iFixit battery? I looked around here for a video or instructions on conditioning, but I do not see anything.
Thanks in advance.
Score 1
3 Comments
So I am now at the stage of draining my battery after a full charge and a two hour charge post full charge. I have removed all energy saving settings. So far so good! I am still at 65% after almost three hours! This is already a huge improvement and very encouraging. My old "new" battery would have died by now. In fact my old battery would drain completely if I hadn't even used the machine for a few days with the lid closed and in my bag. Fingers crossed.
by
I spoke too soon. The ifixit battery has been underwhelming. The discharge goes from 100% to 65% at a normal pace and then drops immediately yo 7% from 65%. This is after conditioning and three cycle. Did this every time. In addition, per coconut battery, the design capacity has dropped to 91% after these three cycles. I either got a bad battery or these seem to be no better than the Amazon battery I replaced it with. In fact the 1.5 year old Amazon battery performed better than this before the swap. I have reset SMC a few times. Ugh.
by
care to give an update of its performance at the moment? cause I was thinking of giving it a try. I am currently using a SLODA battery from amazonuk and it only lasts for about 2 hrs max on minimal web browsing and emails. I just downloaded a gfxcardstatus so I could keep my graphics card to integrated only or whatever that means - I guess Ill try this first
by
Add a comment
Most Helpful Answer
Although not a requirement, I definitely recommend conditioning your battery right after you install it. After that you should charge and fully drain your battery on a regular basis in order to get top performance.
Score 2
2 Comments:
I've seen more issues if you don't calibrate a new battery and besides you do what to make sure the battery is good before depending on it in the field.
by
Thanks Luca, I appreciate the guidance.
by
Add a comment
Follow this procedure: Calibrating Your MacBook, Air, or Pro Battery
Score 1
2 Comments:
This is very helpful. I will follow it to a T.
by
Battery should arrive today. I also found these instructions (2011 video) which differ slightly in that it does not say to shut down the machine after the full drain as the link above states. I would imagine a full drain shuts down the power? or maybe it is in deep standby? Hard to figure out how to shut down when a full battery drain seems to be a shut down? Maybe a press of the power button?
https://eshop.macsales.com/item/Newer%20...
Totally overthinking I am sure, but want this second battery purchase in a year to have better results than the Amazon Atabyone cheapo that didn't improve my experience much.
https://www.amazon.com/gp/product/B01F76...
by
Add a comment
Add a comment
Add your answer
Joe Z will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 863
