27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160 Questions View all
Magsafe led blinking on Thunderbolt display
Hi all,
My Macbook Air no longer charges when connected to my Thunderbolt display.
The led on the magsafe connector is blinking fast (green).
Question: what could be the problem?
Tried: cleaning the connectors / reset PRAM / reset SMC / disconnect power for long period (hours).
All the best from Holland,
Pieter
2 Comments
Does a regular MagSafe charger work? Solid Green and when battery is low Amber.
by
Hi Dan, charging works when I use another Magsafe charger (Solid Green and when battery is low Amber)
by
Add a comment
1 Answer
Chosen Solution
We don't have a cord or power supply replacement guide. If the cord looks OK I would suspect the power supply is having problems. Here is the IFIXIT teardown which can help guide you Apple Thunderbolt Display Teardown and here's a good guide which willl get you in Apple Thunderbolt Display EMI Filter Replacement
Apple Thunderbolt Display Image
Guide
Difficulty:
Moderate
Apple Thunderbolt Display EMI Filter Image
Guide
Difficulty:
Moderate
25 - 35 minutes
Score 2
3 Comments:
Hi Dan,
Many thanks for your answers. The cord looks OK.
The screen is fully functional. Would't there be more problems if the power supply is failing?
All the best,
Pieter
by
The power supply offers multiple power feeds so the MagSafe feed have a problem unlike the other feeds.
by
Hi Pieter,
I'm having a similar problem. Did you ever replace the power supply and did that fix your problem?
Thanks,
Viktor
by
Add a comment
Add your answer
Pieter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 1,005
