Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
588 Questions View all
New iFixit Battery Not charging
I replaced my factory battery with a new iFixit battery. The new battery had 70% when installed, I allowed it to die and now I put it to charge and it stays at 2%. If I unplug the computer it turns off and has to reboot.
Score 2
Add a comment
1 Answer
Chosen Solution
Sounds like your battery is not charging. I would suspect the mag-safe board right off the bat. What was happening with your old battery? Please download and install and run Coconut Battery then post your results so we can get a better idea of what is going on.
http://www.coconut-flavour.com/coconutba...
Score 1
10 Comments:
The old battery was swollen, so I purchased an new replacement
by
macOS Battery Status: Good
Battery Failure: yes
Power adapter: 85 watts
Cycle count:2
Charging with: 0 Watts
Current Charge 136 mAh
Full Charge Capacity 6891 mAh
by
Well it shows to be a failed battery, which is unusual for a battery with only two cycles but it does happen. I would request a replacement.
by
Whats up with battery failures on iFixit batteries? this is probably the 2nd one i've seen today...
by
Right now I don't know if it is the battery. Looks like it was run for one cycle to test it before you got it. We won't know till you try a second one. It can very well be something else.
by
Show 5 more comments
Add a comment
Add your answer
Joseph Granger will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 392
