Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Questions View all
Screen stuck on dimmest setting
Hello,
My iMac is currently stuck with a dim screen, and changing the brightness does nothing at all. I have tried resetting the SMC and PRAM, and the issue is very briefly fixed after a PRAM reset, however the screen dims about halfway through the boot cycle. Any idea why it may be doing this, and how I can resume full brightness?
Many thanks!
1 Comment
Thanks for your replies. As an update, I thought I'd try a few different combinations. I reset the PRAM and immediately booted into safe mode. To my amazement the screen has stayed at full brightness, even when I restart and boot normally. No idea why, Macs still continue to baffle me!
by
Add a comment
Chosen Solution
This is according to just how dim the screen is. If it is almost black, your inverter may have failed or is failing. Here's how to replace it: iMac Intel 20" EMC 2266 Inverter Replacement
Score 2
Add a comment
I don't think that it is stuck on the lowest brightness I think that you back lite went out. Is it just kind faint? If so its your back light so this means it will need replaced before you can get the brightness the rest of the way up.
2 Comments:
The backlight seems to work though, as I can clearly see what's on the screen (I imagine I'd need a torch to see otherwise). Indeed when I reset the NVRAM/PRAM, it briefly goes back to full brightness for about 30 seconds, after which is fades down to the dimmest setting. I'm a bit baffled as it was working fine up until recently.
by
When starting up, hold down t. This will bring you into target diskmode. If it is bright, there is probably an issue with your install. If it isn't there is some other issue.
by
Add a comment
Add your answer
Ryan Fielding will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 238
