Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
replaced broken screen and display is dim
I replaced my broken a screen and it works but it is extremely dim. I went to brightness, cranked it up, but it did not change it. Since i bought two 3GS screens, i installed the second one, but had the same results.
Anyone have an idea?
Score -1
1 Comment
by screen do you mean just the front display glass or entire display including lcd
by
Add a comment
Chosen Solution
My suggestion here is that you do not have the backlight working. Easy for me to guess since I am not looking at your phone. Check out this site and see if it makes sense for your to fix your phone the way it is described. I mean you would have to be pretty unlucky to buy nothing but broken screens. Possible? yes but very unlikely. Just my 2 cents...here is the site http://blog.techsick.com/guides-tutorial...
Score 1
2 Comments:
i agree with your 2 cents
by
ah...it is blown. the people before me did try to install a 3G screen into the 3GS phone....no way for me to fix it at this point.
thanks for the help all
by
Add a comment
Most Helpful Answer
Are the screens original Apple replacement ones, or cheap generic screens? I'm wondering if that may be the trouble. Do you have any screen, cracked or otherwise, that is original which you could temporarily connect and will give an indication of brightness level? You could then confirm that it isn't another hardware issue within the phone, but is actually the new screen.
Score 1
2 Comments:
the display assemblies were purchased via IFixit
by
oh..and i have put the original cracked screen back in and the same problem exists.
by
Add a comment
hmmm....make sure your lcd is connected properly...connection number 2....try a hard reboot by holding the top and bottom button together for like 10 secs
1 Comment:
i have already done that with two new screens? any other options?
by
Add a comment
had the same problem. tried everything but checked the settings and saw that the settings were turned down. turn it all the way up and see what you find.
Add a comment
Water Damage to the logic board will cause the back light on the LCD to function improperly. Or you might have two broken LCD need to try an LCD you know is working. Good Luck
"That's a bummer man! It's uh...it's a bummer." -The Dude
Add a comment
Add your answer
rdt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,217
