Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
Will only boot to the folder with question mark
My first Imac will only boot to the folder with question mark. I bought a second and similar imac and changed the hard drives but this first one will still not boot with the new hard drive. However on the second Imac both hard drives will boot
What could be the problem with the first Imac?
Score 1
Add a comment
Chosen Solution
A folder with a question mark means the computer cannot find a start-up folder. If you are getting this, it's not booting correctly. If the computer eventually boots, go to the System Preferences and select the start-up drive you want it to boot from. If it fails to boot at all then boot from your system installation DVD and go to the second screen pull down menu to Utilities -> Disk Utility and see if it will see the hard drive. If it does try repairing it.
Score 2
Add a comment
Cable
or connector... more serious (logic board) problem if there was an electrical spike to the first one.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Score 1
Add a comment
Add your answer
Francis Obi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 1,865
