Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
Keyboard and TrackPad not working...
Keyboard and trackpad for MacBook A1181 is not working in its original machine... I have tested this keyboard and trackpad by installing into another MacBook(same model) and its work well and good...power button is working as well....
what seems to be the problem??? hope you can help me figure out the problem... thankss
Add a comment
Chosen Solution
did you check if another topcase works on your macbook? because if both don't but they work on a different macbook, your board might be cooked.
2 Comments:
is there a way to fix the logic board?
by
Look in the socket for blockage
by
Add a comment
Most Helpful Answer
Recently I refurbished a Macbook A1181 (version 4.1 , the one @2.4Ghz) and I had the same issue.
When I finished the repair and mounted the keyboard and trackpad back on, as well as the battery, I realized they where not responsive, despite the power button still worked.
I read in a forum there was an issue with this particular model and the ground level, making that both the keyboard and the trackpad don't work.
What I did was sticking a tiny little piece of a plastic sheet between the metal case and a little gold V-shaped connector that is spotted in the left side of the battery connector board (if you watch it from the pins side), to avoid contact between them. This worked for me.
Hope this helps.
Score 1
1 Comment:
can u please share more details ,because i face the same problem......
by
Add a comment
Add your answer
Cled Tayamen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 2,234
