Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Questions View all
iMac not detecting SSD
I have replaced my primary HDD with SSD. But my i mac is not detecting SSD. I can't see it in disk utility about from "System report i can see it". Please review screenshot from :https://www.dropbox.com/s/tsgnx6bdj029wb... when i execute diskutil commands.
1 Comment
Add a comment
1 Answer
Most Helpful Answer
To start with the Kingston SUV400S37 SSD is a SATA III (6.0 Gb/s) drive which by the spec sheet also is able to run at SATA II (3.0 Gb/s) interfaced systems. So it should work from that perspective. But! You likely need to update its firmware as well as your system. Here's the Kingston drive tools: SSD Manager Sadly it requires MS Windows to run. So you'll need to take your SSD out and use a SATA to USB adapter to hook it up to a Windows system to make sure the firmware is up to date as well as lock the SATA speed if you can to SATA II.
As for your Mac you'll need to put your old drive back in (if its still working) so you can check your systems firmware level. Here's the Apple T/N you'll need to reference: About EFI and SMC firmware updates for Intel-based Mac computers Make sure you're at the listed version or newer.
Let us know how it goes.
Score 2
4 Comments:
Excellent! i will give a try tonight thank you! Regarding firmware update i think i have the latest one though i will confirm it.
Again thank you for your help! I will get back to you asap.
by
Do i need any imac to ssd sata 3gb/s data cable?
by
Not sure I follow you here. The current cable in your system should be just fine (don't mess with it).
As to connecting the drive to your Windows system you'l need a SATA to USB adapter like this one: Startech 2.5" SATA to USB adapter.
by
Okay got it thanks! Yet i didn't get chance to lock the sata speed. I will do asap and update you.
by
Add a comment
Add your answer
Dipen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 870
