0
Score
Asked
Screen back light flicker
Macbook 2.4 GHz Intel Core 2 Duo
My fiancee's computer is starting to have problems with the screen flickering. It can be corrected sometimes by tilting the screen or other times by changing screen brightness level.
I couldn't find this listed on your site as a common problem. I read one place that it might be an inverter issue of some sort, but located a lot of unknowns.
Would you be able to tell me if this is common and if it has a common fix and if you have the parts available for order?
Thank you,
Nathan Blaesing
2
Score
mayer
148.9k
Answered
The most likely problem is the Display Data Cable. It runs through the hinge and gets worn., Here's the part: MacBook Display Data Cable
