Vertical lines only on screen
I have bright colored vertical lines on the screen ONLY!
If I twist the screen (hold the upper left corner and pull the upper left corner down towards the keyboard the lines go away and I have a normal screen.
Help? sure get tired twisting the screen.
twisting the screen clears the problem --must be a connection problem NOT firmware problem
1 Comment
Was a solution found?
by Daniel
