1.83, 2, or 2.16 GHz Core Duo processor
281 Questions View all
Both fan not working
Hi all
my old macbook pro has this problem. Both fan are at 0 rpm. I checked both and are not malfunctions... seems to be a problem with the SMC.
Important note: actually the MBP is working WITHOUT battery.
Question: use the laptop without the battery may affect the normal operation of the SMC and then keep the fans switched off?
Should I order a battery replacement for fix this?
Thank you
Score -1
Add a comment
Chosen Solution
Boot up from original system installation dvd, see if fans are running to eliminate possible software issue.
Score 3
3 Comments:
Thanks for accepting my answer. Please tell us your result in case this question comes up for someone else.
by
Fan not working anyway not even after resetting SMC...
I remember that the fans have always worked until I broke down the battery. Since I removed it, the fans have stopped working. I've ordered a new battery... I'll try to reset SMC after installed and charged it...
by
Please don't accept an answer till you have a solution because we stop looking at accepted answers questions.
by
Add a comment
First I would do a SMC reset. Follow this Apple T/N: Resetting the System Management Controller (SMC) on your Mac.
SMC has a few different functions. So while it manages battery charging and battery power management. This part of SMC does not involve the temperature management side of things.
I do strongly recommend putting the battery back in (replacing it) only because when you don't have it present it doesn't take much to pull out or cause a power disconnect from the power adapter. The way the system was designed the battery would fill in the power disruption. Think of it this way your laptop has a built in UPS!
Score 1
Add a comment
Add your answer
mbonomi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,646
