Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
747 Questions View all
re-installing OS X Yosimite
i recently Sold my Macbook. i un installed the OS X as i have in the past, but when i try and connect to the Apple Store it keeps saying
"This item is temporarily Unavailable, Try again Later"
this happens every time i try and RE-Install. Please help
Thank you
Score 2
2 Comments
How did you do this uninstall? How are you trying to connect? Did you erase the drive?
by
i uninstalled it using the Disk Utility but when i go to the Reinstall option i get the error message "This item is temporarily Unavailable, Try again Later"
by
Add a comment
Chosen Solution
how did you uninstall it?
anyways if you are trying to install yosemite there are a number of ways to do that
though its a long process, it works fine
first you have to download the yosemite OS externally and then you have to make it into a bootable drive, here's a guide on how to do that please note that since you cant connect to the appstore you will have to download yosemite another way
www.macworld.com/article/2367748/os-x/how-to-make-a-bootable-os-x-10-10-yosemite-install-drive.html
Score 1
1 Comment:
by
Add a comment
Most Helpful Answer
You'll need to manually download the OS installer and save it on a bootable drive. You will then need to boot up under this drive to then install the OS.
Apple's OS recovery downloader is having problems.
Score 3
2 Comments:
I've been working on this for a long time, so this is the answer....
Seems like I have to reinstall it manually.
Thanks a lot!
by
I've been working on this for a long time.
Thanks a lot.
by
Add a comment
Add your answer
fredykruegerman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 27,576
